Hi all.. just really trying to get some info. Currently im driving a series 2 type-s legnum(fully optioned) and im contemplating looking for a swap to a v35..
What sort of police attention do you get in them(currently dont get looked at once even with 18" rgteks on it) also parts etc availability? Just really testing the waters atm.. any info would be good...
Edited by vr4sthoz
https://www.sau.com.au/forums/topic/423788-looking-at-getting-a-v35/
I don't ever get looked at - even with my old body kit and wheels hanging out the guards. Parts are easy as they are mechanically nearly identical to the 350Z, and parts are cheap out of the USA. Do you want a black one with lots of mods? Buy mine :) I am thinking about getting a V36 :)
Cheers for the info.. prob looking at swapping etc.. and possibly the 4 door... still need to keep the family aspect of the car.
Think i will havw to go drive one.. going from twin turbo v6 to na 6 probably will be quite different...
Calculated plus i had a high flow cat chucked in.. we know it was out a bit.. looking 165awkw calculated plus the extra gain from the cat(had complience one on it) been told i should have gained an extra 5-10 out of that.. so i went the lower figure to be safe. Still might come out higher.. just waiting on the fixed results..
Edited by vr4sthoz
He was first on Friday so they took ages trying to work out why the power was so low - was under 100 before the tune. Finished around 130, which he thinks is 160ish, through the auto trans. On sat night they reflashed the trans ecu to change shift points and shift peed. Overall a big improvement, but Its still a magna:) Steve said he was looking into v35ecu tuning.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
