Hi all.. just really trying to get some info. Currently im driving a series 2 type-s legnum(fully optioned) and im contemplating looking for a swap to a v35..
What sort of police attention do you get in them(currently dont get looked at once even with 18" rgteks on it) also parts etc availability? Just really testing the waters atm.. any info would be good...
Edited by vr4sthoz
https://www.sau.com.au/forums/topic/423788-looking-at-getting-a-v35/
I don't ever get looked at - even with my old body kit and wheels hanging out the guards. Parts are easy as they are mechanically nearly identical to the 350Z, and parts are cheap out of the USA. Do you want a black one with lots of mods? Buy mine :) I am thinking about getting a V36 :)
Cheers for the info.. prob looking at swapping etc.. and possibly the 4 door... still need to keep the family aspect of the car.
Think i will havw to go drive one.. going from twin turbo v6 to na 6 probably will be quite different...
Calculated plus i had a high flow cat chucked in.. we know it was out a bit.. looking 165awkw calculated plus the extra gain from the cat(had complience one on it) been told i should have gained an extra 5-10 out of that.. so i went the lower figure to be safe. Still might come out higher.. just waiting on the fixed results..
Edited by vr4sthoz
He was first on Friday so they took ages trying to work out why the power was so low - was under 100 before the tune. Finished around 130, which he thinks is 160ish, through the auto trans. On sat night they reflashed the trans ecu to change shift points and shift peed. Overall a big improvement, but Its still a magna:) Steve said he was looking into v35ecu tuning.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
