just got my rb25 tuned the other day with the td06sl2 10cm, greddy copy, 440cc injectors, aftermarket throttle body, custom low mount steampipe manifold, full 3 inch exhaust, bosch 040 fuel pump.
Car made 268 hp on 15 psi and it started to lean out on full throttle.. and this is my problem now D:
tuner said tps could be and issue wiring wise, could bereading backwards or opposite or something..
mabey faulty fuel pressure reg? im running a sard fpr but i think it was faulty from the start so i am changing this, thoughts anyone?
https://www.sau.com.au/forums/topic/423794-running-lean-full-throttle/
So you are running the 040? I have heard the mesh filter on the bottom blocks up restricting flow, I think some have cut the mesh out.
Definitely run a direct 12V feed from the battery through a fuse and relay, using thick wire as GTSBoy mentioned. There is a how to in the DIY section.
yep he also said to do the fuel pump thing as you guys are saying so i am going to start with that first :) because atm its just wired to the original pos and neg wires in the fuel tank and thats where im going wrong i think ..
Edited by jiri styles
