S A U - N S W Texikhana - Queen's Birthday Holiday Monday
Cheater tyres...check
new suspension.....check
longer extension code....check
money sent.....check
form sent.....check
looks like we are ready to go.
LOL!
I'm going to take a magnet, and kill that leaf while uncle duncan isn't looking. Leave approved! I'll do some forms and stuff I guess, first time driver!
Take a mulcher, it should do leafs!
I shouldnt pick on it, it'll kick my ass :P
PM's sent to all confirmed entries so far.
Also, I've got payment but no forms from Kivan Ahmadi - can you shoot your forms off to [email protected], and I'll 100% confirm you.
Just sent you an email man! :yes:
sorry, ive been away.. will email it on monday when ive got access to a printer
No worries dude! Just trying to make sure I've got everything in order and I wasn't sure who you were :) No huge rush.
thx matt
also - volunteers, usually 8am is an awesome time for arrival (from memory). helps to get the trailer unloaded, courses set up, people lining up in the right spot, etc.
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
