S A U - N S W Texikhana - Queen's Birthday Holiday Monday
ugh more maps to setup
I have suggestions. Figure 8 skidpan. I can draw it for you if you like? ;op
Also... something that requires entering a largish circle, and going around it a few times, and optionally indicating to exit it. ;o)
ah yeah sorry forgot to respond. yours is fine :)
busy at work as per usual.
No problem at all, as long as you have it i am happy ;)
Did a quick read
If I never done a SAU day but have cams L2 licence how much do I need to pay
Are fire extinguishers mandatory? Due to the no gate rule will bring out the V35 instead of the 14 but dont really want to be hacking that up to mount an extinguisher
As per facebook thread, yes to extinguisher. Read the "first timers" thread linked in the first post for all the details of what you need. (helmet, extinguisher etc)
shouldn't be much if any hassle fitting a fire extinguisher.
how is the bottom part of the back seat held down on a v35, is there a bolt?
if not, you can use a simple piece of aluminium between the passenger seat bolts like we did in the leaf.
randy, facewhatnow?
Oh I paid full amount & I'm a first timer.
Don't mind paying the full, might be bringing my girlfriend along for some passenger rides, can my extra tenner cover that too?
Ha! Nice one man!
Yeah, I'm going to give my wife a couple of rides. And happy to take any other passengers though the day! If I don't break it early!
Innapropriate for an SAU day, but hey i support it :woot: lolz
Considering how bad my driving is, There's every chance I'll be going home a single man.
This would not surprise me :laugh:
I'll be bringing down a gopro 3 on the day as well so i'll be looking for volunteers for car footage :)
If you put it on FeZ25s car put it away from the roof as that's where the car will end up lolz
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
