S A U - N S W Texikhana - Queen's Birthday Holiday Monday
it was the only weekends they would give us :(
I know it is not good for the club dollar-wise, but I loved the Bathurst long weekend Texi.
Almost no-one there, and after lunch I finished a run, went to a nonexistent queue, and went right back on again after the guy infront finished his run. So epic. I think I got 30 runs that day and nuked 3 out of 4 tyres!
Also, here is my install.
I mounted the bar to the bolts that hold the seat to the rail, so the extinguisher moves with the seat.
Only downside to having it permanently mounted (although I can whip it out pretty quickly. heh heh. ;o) is that the black handle *can* get caught on my wife's dresses/skirts.
521324_10150934847196810_1249067364_n.jp
Wow nice job there Randy!
Mine is mounted off the rear seat, just did the same with the cruiser too! Can never have enough Extiguisher :P
For those with GTR's/ Stag's etc and are lazy/like pre fab :
http://www.skylinesaustralia.com/forums/topic/376435-cams-approved-fire-extinguisher-bracket/
My Car is a daily and I leave it in. You get used to stepping over it and now don't notice at all.
Thanks mate!
That's so true. I keep mine in the car 24x7 and most of the time i'm the only one in it so the passenger side is really the best place for it. I can reach it and release it with one hand, and it's nice to know that if there is an electrical fire or you go to help someone in a car accident that you have an extinguisher on hand.
Thanks mate!
Yeah the cabin of the 34 is small enough to have it in the passanger rear footwell and still have easy access :)
Mine's in the passenger rear footwell of my Stagea too, and even if there are people travelling in that spot in the back seats it barely interferes with foot room.
Sorry guys - got home pretty late from work last night and just crashed out. I'll do my best to get it done over the weekend - if it's not done by the AGM, everyone there will bug me about it until it's done.
Will see you there man :D
Does she still get surprised when it goes off unexpectedly between her legs?
Just paid and sent in registration forms. Just in regards to the cams/aasa licence... which one is better? I don't have either so will need to sign up for one on the day.
Eddie.
If you're only looking to do Texi events, go AASA - less bullshit and it's cheaper.
edit::
I should have responded to everyone by now that's emailed - I'll figure out numbers tonight.
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
