Morning chaps.
Yesterday, I took delivery of my new 2002 Nissan Stagea Axis Autech model from Northshore Prestige. Having recently sold my R34 Skyline due to not being able to fit film gear in the Liner, I went on the search for a new car. I was looking for something cool, auto, with a bit of power, upgradeability, comfort and most of all, space to fit all the things. After having driven a few different cards (VE Wagon, Legnum, etc) I went and saw Ben from Northshore Prestige, and took the car for a drive. It basically ticked all the boxes, and I left a deposit on it that day. Its done 104ks.
After having the car for 1 day, my initial thoughts are as follows.
1) The suspension/body roll is horrible. I will definitely be investing in some swaybars to stiffen the body roll up a little bit.
2) The seating position is rather high. I would ideally like to put some lower seats in, but its not a HUGE issue.
3) The auto gearbox is one of the most sluggish POS's that I have ever experienced. This is something that will definitely get attended too.
4) The car feels very restricted. I would imagine freeing up the intake and exhaust will make it breath much better.
Other then that, I'm really happy with it. It talks to me in Japanese everytime I turn the car on as well, which was pretty unexpected at first.
I'd like to get a new dash facia so that I can fit an aftermarket head unit with bluetooth and ipod connectivity as well.
Can anyone tell me what wheels these are? They seem to be factory Nissan 18"s.
Pics: (I will get some better ones this weekend, these are the dealer photos)
Cheers,
Shaz
Edited by XS80ST
https://www.sau.com.au/forums/topic/423805-build-thread-02-stagea-axis-autech/
Hai new stag owner!
Great purchase. Looks clean as.
If you haven't already the forum has all the information you need for most of the points you listed.
Daleo for swaybars and brace. Justjap I think for BC coilovers?
Jetwreck for shift kit.
Scotty for dump and front pipe.
Unsure of the wheels? Look like wheels off an AR-X or something?
​Fascia kits are available off ebay and I'm sure there is a thread where you can use aerpro harnesses to accommodate a new head unit for the things you mentioned.
Edited by M35woah
Hey buddy,
Yep, been in contact with Scotty already about a dump/mid pipe. Will be throwing some cash his way as it becomes available. I have read all the positive results from Jetwrecks valve body upgrade, and will also be doing that as soon as possible.
Will hit up Daleo for the swaybars. I don't particularly want to go coilovers, so maybe just get some lowered springs. I saw there was a gent on here selling a set of eibachs for $200 at the moment. Also, brake wire cut mod is on the list of things to do.
Cheers,
Shaz
Congrats on the purchase.
Wheels are stock AR-X rims.
Goods springs are nismo ones. The rest pale in comparison IMO. Had eibachs, wouldn't go back. Your in the right track with the other things. Get some good pads and fluid in it to get the most out of the stock brakes.
Had an EZlip left over from a whole heap that I brought into Aus, so I chucked it on the front bar. I generally do this with most of my cars, as it stops the majority of scrapes and scratches on the front bar when bottoming out.
Looks okay too!
1EB8F94A-2B28-4554-B0BB-3FB9ECFDFFA2-103
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
