Morning chaps.
Yesterday, I took delivery of my new 2002 Nissan Stagea Axis Autech model from Northshore Prestige. Having recently sold my R34 Skyline due to not being able to fit film gear in the Liner, I went on the search for a new car. I was looking for something cool, auto, with a bit of power, upgradeability, comfort and most of all, space to fit all the things. After having driven a few different cards (VE Wagon, Legnum, etc) I went and saw Ben from Northshore Prestige, and took the car for a drive. It basically ticked all the boxes, and I left a deposit on it that day. Its done 104ks.
After having the car for 1 day, my initial thoughts are as follows.
1) The suspension/body roll is horrible. I will definitely be investing in some swaybars to stiffen the body roll up a little bit.
2) The seating position is rather high. I would ideally like to put some lower seats in, but its not a HUGE issue.
3) The auto gearbox is one of the most sluggish POS's that I have ever experienced. This is something that will definitely get attended too.
4) The car feels very restricted. I would imagine freeing up the intake and exhaust will make it breath much better.
Other then that, I'm really happy with it. It talks to me in Japanese everytime I turn the car on as well, which was pretty unexpected at first.
I'd like to get a new dash facia so that I can fit an aftermarket head unit with bluetooth and ipod connectivity as well.
Can anyone tell me what wheels these are? They seem to be factory Nissan 18"s.
Pics: (I will get some better ones this weekend, these are the dealer photos)
Cheers,
Shaz
Edited by XS80ST
https://www.sau.com.au/forums/topic/423805-build-thread-02-stagea-axis-autech/
Hai new stag owner!
Great purchase. Looks clean as.
If you haven't already the forum has all the information you need for most of the points you listed.
Daleo for swaybars and brace. Justjap I think for BC coilovers?
Jetwreck for shift kit.
Scotty for dump and front pipe.
Unsure of the wheels? Look like wheels off an AR-X or something?
​Fascia kits are available off ebay and I'm sure there is a thread where you can use aerpro harnesses to accommodate a new head unit for the things you mentioned.
Edited by M35woah
Hey buddy,
Yep, been in contact with Scotty already about a dump/mid pipe. Will be throwing some cash his way as it becomes available. I have read all the positive results from Jetwrecks valve body upgrade, and will also be doing that as soon as possible.
Will hit up Daleo for the swaybars. I don't particularly want to go coilovers, so maybe just get some lowered springs. I saw there was a gent on here selling a set of eibachs for $200 at the moment. Also, brake wire cut mod is on the list of things to do.
Cheers,
Shaz
Congrats on the purchase.
Wheels are stock AR-X rims.
Goods springs are nismo ones. The rest pale in comparison IMO. Had eibachs, wouldn't go back. Your in the right track with the other things. Get some good pads and fluid in it to get the most out of the stock brakes.
Had an EZlip left over from a whole heap that I brought into Aus, so I chucked it on the front bar. I generally do this with most of my cars, as it stops the majority of scrapes and scratches on the front bar when bottoming out.
Looks okay too!
1EB8F94A-2B28-4554-B0BB-3FB9ECFDFFA2-103
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
