Hi all,
hoping someone has done this...
A friend is offering me a set of the stock GTST 4 pot front & 2 pot rear brake calipers and brake lines [i am assuming is from the gtst]
Will it be as simple as just swapping/installing around my brake calipers?
i am using the r33 NA sedan and i believe the front = 2pot and rear are drum brakes.
I am also using 17x9 +30 wheels. hoping there will be no clearance issues as i am not a fan of spacers.
Will it be too much of a hassle ?
thanks for feedback
https://www.sau.com.au/forums/topic/423819-r33-gtst-brake-calipers-on-r33-na/
  • 3 weeks later...
You got any R33 GTS-T front brake calipers in stock? Mines got a sticking piston so want to rebuild it. Will be easier to do it to another set of calipers then just swap them over.
If it breaks up a set then I can send you my calipers in return
2013 MERCEDES BENZ SL-CLASS
