Has anyone ever had the rods that connect to the Hicas lock bar come free while they are driving? ( If someone could tell me the name of the rods it would be great ).
I have a lock bar in my R33 and i recently installed some Tein Super Streets. Now when i put them in I got new tyres put on the back and a wheel alignment done. Turns out the tyres rubbed, so i lifted the coilovers up a bit which threw the toe out. I then got another alignment done, and the car still didnt feel right, but i put this down to the new tyres ( rookie mistake, wont ever be doing that again).
Was driving along the other day and the rod that connects to the hicas bar came out of the bar ( pretty scary experience doing 80 along a narrow country road ). anyways no major damage was done. had a look under the car for the 1st time since today, and noticed the other side was loose as well. i did the things up bloody tight when i put them on.
Could they have come loose of their own free will? or would they have to have had a helping hand?
https://www.sau.com.au/forums/topic/423820-rods-came-out-of-hicas-lock-bar-r33/
The mechanism that controls rear turning has a ball-joint the same as the tie end rods at the front. Kind of like a chicken leg. These wear out over time. On others cars it doesn't seem to be much of a problem. But The two R33s I have (I convinced by dad to buy one) Both of them had funny rear toe settings when we got them. As in one wheel was out of whack to the other. Hicas problem or poor wheel misalignment, I don't know.
If I gave the car some power around a corner to try break rear traction, I felt like the rear wheels bent which everway the force pushed them before breaking traction, then I would hear a deep clunk, kind of like the chicken bone tie rod popped out and in again as the force was being applied and ease of again.
After I had a wheel alligment done (I run neg .05-1mm toe in on the back) the problem is mostly gone. but my point is with the sloppiness of the R33s rear, its possible these tie rods wear out a lot and eventually can become loose enough to pop out.
I also had my front tie end rods at the front replaced on my car, The old ones I had taken out were clunky and had lots of play. I don't know how far they were from popping out.
http://www.ebay.com/itm/2-OUTER-TIE-ROD-END-FOR-NISSAN-R32-89-94-2WD-R33-95-98-2WD-R34-99-04-/251028114720?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a72710d20&vxp=mtr
I should probably look into replacing the tie rods at the back as well, but I'm not sure what kind of tie rods they run.
Hopefully we can get some more information here.
Edited by sonicz
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
