Trex Posted April 19, 2013 Share Posted April 19, 2013 The rear link looks like it's about to pop off, its the same on both sides. Is everyone else's the same? 1 Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/ Share on other sites More sharing options...
krzysztof Posted April 19, 2013 Share Posted April 19, 2013 yeah mine looks the same - it wont come off Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6821395 Share on other sites More sharing options...
White GTS-T Posted April 19, 2013 Share Posted April 19, 2013 (edited) Did you tighten them up while the car was at ride height, i.e., on the ground, or while the vehicle was in the air, with the suspension at fool droop? Edited April 19, 2013 by White GTS-T Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6821396 Share on other sites More sharing options...
Daleo Posted April 19, 2013 Share Posted April 19, 2013 Auto Rear crossmember?They are 50mm wider than the manual; which is what the Whiteline bar is made for. Whiteline's Heavy Duty Ball Links cope much better with the extreme angle. KLC109 I can help you out with these if you're interested. Cheers, Dale. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6821417 Share on other sites More sharing options...
Trex Posted April 19, 2013 Author Share Posted April 19, 2013 Thank you for the quick replies. I had my mechanic do them, they know their stuff so they would have done it correctly. I'm going to jack up a corner and see how the angle changes It's auto daleo, my mechanic and i thought the bar was about 5cm too short, that would explain why haha. I've saved your contact info because i wanted to change the F&R endlinks in a year or two. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6821480 Share on other sites More sharing options...
Daleo Posted April 19, 2013 Share Posted April 19, 2013 Thank you for the quick replies. I had my mechanic do them, they know their stuff so they would have done it correctly. I'm going to jack up a corner and see how the angle changes It's auto daleo, my mechanic and i thought the bar was about 5cm too short, that would explain why haha. I've saved your contact info because i wanted to change the F&R endlinks in a year or two. Cool, no worries mate. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6821591 Share on other sites More sharing options...
Ben C34 Posted April 20, 2013 Share Posted April 20, 2013 (edited) i'm just about to buy a rear bar myself. Its a series 2 auto rwd. Is the white line bar the best option? those links don't look the best. Sorry for thread jack I suppose you could add some spacers and use longer bolts to reduce the angle. Edited April 20, 2013 by superben Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6822143 Share on other sites More sharing options...
Trex Posted April 21, 2013 Author Share Posted April 21, 2013 judging from daleo's post the whiteline bar will fit your rwd perfectly with the links provided. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6823166 Share on other sites More sharing options...
Ben C34 Posted April 21, 2013 Share Posted April 21, 2013 judging from daleo's post the whiteline bar will fit your rwd perfectly with the links provided. well its not perfect due to the 50mm difference which is why I asked. I suppose that's what everyone uses and just ignores the angle issue. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6823370 Share on other sites More sharing options...
Trex Posted April 21, 2013 Author Share Posted April 21, 2013 (edited) well its not perfect due to the 50mm difference which is why I asked. I suppose that's what everyone uses and just ignores the angle issue. awd cradle is 5cm wider then the rwd. hence no link angle. I don't know from personal experience, but Daleo is a whiteline seller http://www.whiteline.com.au/do_segue4.php?make=NISSAN&model=STAGEA&model_final=STAGEA+WC34+RWD%2FAWD&vehicle=1996-9%2F01 Edited April 21, 2013 by OS80RN Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6823394 Share on other sites More sharing options...
Daleo Posted April 22, 2013 Share Posted April 22, 2013 You're right OS8ORN; from my understanding, the rwd subframe is spot on. It's only auto awd subframe that is an issue. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6824639 Share on other sites More sharing options...
Ben C34 Posted June 13, 2013 Share Posted June 13, 2013 OK, so I fitted my whiteline sway bar and same issue, too narrow. It is on a S2 RWD RS I wasnt happy with the mental angle so I machined up some spacers to sort it. Also had to slot the holes in the U brackets to be able to get them on. HEAPS better handling, DO IT PEOPLE!!! Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6889440 Share on other sites More sharing options...
whitenight27 Posted August 29, 2013 Share Posted August 29, 2013 what if u just made up a spacer for each side between the bar and the bush? so if is 5mm short then have a spacer for each side 2.5mm Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6994393 Share on other sites More sharing options...
Ben C34 Posted August 29, 2013 Share Posted August 29, 2013 Yep, I machined up some spacers. Was 12mm each side. Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6994635 Share on other sites More sharing options...
whitenight27 Posted August 29, 2013 Share Posted August 29, 2013 Chears thanks for that superben Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6994762 Share on other sites More sharing options...
whitenight27 Posted August 29, 2013 Share Posted August 29, 2013 I am guessing u needed longer bolts as well Link to comment https://www.sau.com.au/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#findComment-6994764 Share on other sites More sharing options...
