Auto Rear crossmember?
They are 50mm wider than the manual; which is what the Whiteline bar is made for.
Whiteline's Heavy Duty Ball Links cope much better with the extreme angle.
KLC109
I can help you out with these if you're interested.
Cheers, Dale.
Thank you for the quick replies.
I had my mechanic do them, they know their stuff so they would have done it correctly.
I'm going to jack up a corner and see how the angle changes
It's auto daleo, my mechanic and i thought the bar was about 5cm too short, that would explain why haha. I've saved your contact info because i wanted to change the F&R endlinks in a year or two.
Cool, no worries mate. ;)
i'm just about to buy a rear bar myself. Its a series 2 auto rwd.
Is the white line bar the best option? those links don't look the best.
Sorry for thread jack :)
I suppose you could add some spacers and use longer bolts to reduce the angle.
Edited by superben
judging from daleo's post the whiteline bar will fit your rwd perfectly with the links provided.
well its not perfect due to the 50mm difference which is why I asked. I suppose that's what everyone uses and just ignores the angle issue.
awd cradle is 5cm wider then the rwd. hence no link angle.
I don't know from personal experience, but Daleo is a whiteline seller
http://www.whiteline.com.au/do_segue4.php?make=NISSAN&model=STAGEA&model_final=STAGEA+WC34+RWD%2FAWD&vehicle=1996-9%2F01
Edited by OS80RN
  • 1 month later...
OK, so I fitted my whiteline sway bar and same issue, too narrow.
It is on a S2 RWD RS
I wasnt happy with the mental angle so I machined up some spacers to sort it.
Also had to slot the holes in the U brackets to be able to get them on.
HEAPS better handling, DO IT PEOPLE!!!
  • 2 months later...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
