Hi guys, I've been trying to figure out what's happening with my 2002 250GT and so far this is what I've been able to find using the NDS2 software.
Fuel pressure reads about 6.8 - 7.0 at idle to 10.3 at WOT. When I disable the fuel pump, let the pressure drop then enable it again, there's a whirring noise like a stuck bearing as the pressure builds up.
I'm assuming this is the high pressure fuel pump, although it isn't really specified (there's only 1 'Fuel Pump').
Has anyone else experienced this before? And if it is my high pressure pump, any idea what the issue may be?
Cheers
https://www.sau.com.au/forums/topic/423822-v35-250gt-fuel-pump-issue/
  • 1 year later...
Hi guys
I have a 2002 250GT V35 skyline, last week i took it for diagnostic cause the CEL came on and the results were as follows:
1. PO191 Fuel Rail Pressure Sensor Range/Performance
2. Mass or Volume Air flow Circuit
3. Knock sensor 1 Circuit High Input (Bank 1)
When i drove the car back home, there was no power in it at all, it would only get up to about 20 or 30kms/hr.
I changed the Airflow sensor and she seems to run a little better but there is no power in it, when i reach around 3000rpms she starts jerking.
Can anyone help me please. Do i need to change the Fuel Rail Pressure sensor? if so Where can i get one and does anyone know the Part number?
Please help. my email address is [email protected].
Thanks
Monzie
Edited by Monzie
The AFM is a common issue, especially in the turbo VQ25, but it sounds like you may be having issues with fuel supply.
I would start by checking the fuel pressure is within specs. Those high pressure mechanical pumps can fail, so can the one in the tank. Replace the filter intank for a start.
  • 3 weeks later...
Hi guys
So since the last time i posted a thread, these are the developments:
I changed the fuel rail pressure sensor. (what a mission to get to), the engine check light went off, drove it and it seemed a little better but still no kick down when you accelerate. it will drive normally, changing through the gears seems normal but when you put your foot down it just doesnt go like it should. the mechanic checked
the Fuel pump and filter in the tank and found the filter to be blocked, he changed both the filter and the pump in the tank with new ones and its still doing the same thing, drives normally and changes the gears normally but when you put your foot down there is no kickdown at all. now the diagnostic is reading the knock sensor as faulty, changed that as well and still no joy.
Can anyone help please.?
Monzie
What diagnostic reader is he using? Sounds like it's in limp mode still.
If there was a fuel supply issue, then the knock sensor would be picking up knock and doing it's job correctly. Not all faults will display an engine code, and sometimes the code it does show isn't related to the fault, but is a symptom of it.
Hi Paul and scotty
Thanks for the responses.
Im not sure what reader they using but i think its the same one that our nissan dealer is using at their workshops.
The mechanic has removed all the catalytic converters from the vehicle ( not a problem in our country), we changed the fuel filter and pump in the tank as well as the sensors. took off the high pressure fuel pump that sits near the fuel rail pressure sensor (it was full of dirt) blew it out and tried it again but still doing the same thing, it drives fine but no kick down when you put your foot flat. the mechanic is suspecting that the high pressure fuel pump is gone, we couldn't strip the one we took off to really clean it out.
The mechanic said his getting another one off another skyline to try and see if there is any difference. he also told me that he has another skyline doing the same thing.
I really dont know what to do or think... they are such beautifull cars....
any suggestions????
  • 3 weeks later...
Hi Scott
Yes it was the HP pump, apparently there are some piston like parts in the HP pump that were not working to well due to sludge, he managed to clean them out and the machine started working again, its not 100% like before but still got loads of power, having removed the catalytics seems to have given it better fuel consumption.
the mechanic says it will be fine for now until i can buy a new HP pump.
he recommends that regular oil changes should keep it from happening again.
Thanks for all the help guys, and hope this will help anyone who experiences this problem in the future.
Edited by Monzie
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
