GTSboy, thanks for the info. At the end the day I'm shovelling shit uphill really. I went had a chat with a local tuner today, he also didn't recoment changing airflow meter size. Didn't go so far to bag the pfc but recomended using a link ecu, which is an option I like and would do, but I already have the pfc, and link will stretch my bidget a bit farer than I'd like. There's no real rush here, so will take my time a bit, see if I can on sell pfc, or will make the intake 3inch and stick with zx airflow. thanks for all your inputs.
I think you should maybe look at a different tuner, why would you go and sell the power fc just so this tuner can tune a "link ecu"?
The power fc is perfectly capable of meeting your needs, i know this because i have one and im running a Z32 with a 4inch pipe off the gt3076 and it has a 4inch to 3inch reducer just before the Z32, its in the tune and it will be fine to do it this way... Find yourself a guy thats competent in Power fc tuning and just do it.. no problem
The tuner didn't say I have to go to a link. They were fine with pfc, and actually commented that they are usually straight forward and reliable to tune. He recomended the link as alternative, albeit a costly alternative. I would still need to buy a zx airflow, here they're roughly 200-300 second hand, or 500 genuine new. That cost, plus my original purchase of pfc is starting to get close to price of a g4, so if I can onsell pfc, I'll look at link, otherwise will do the 3inch reduction to a zx airflow meter.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
