Alpine 12" Type S Subwoofer in Black Sealed Box
Looking for: $110
Bought brand new in early 2011, well looked after. The speaker itself is in perfect condition, no signs of wear or tear. Has never been pushed hard, should make a great addition to any system. The box was in great condition until I took it out of my car and my cat decided it looked like a scratching post, so you can see in the pictures he managed to tear and lift some of the carpet a little bit, other than that the box is still in good condition.
Approximate box dimensions: 430W x 430D x 340H
Cadence Xa175.4 - 4 Channel Car Amplifier
Looking for: $110
Bought brand new, online from the USA in early 2011. This has been a great amp which was powering 2 x 6" splits and the above sub in my old car. I was really happy with the combination and this amp performed really well.
The fan in the amp started making a bit of noise not long before I sold my car, so I've popped it open and replaced the fan with a new one. However I don't have a car to fire it up with and check the new fan is running nice and quiet, so if you're interested feel free to come around and give it a test.
110W x 4 @ 4 ohm RMS, 175W x 4 @ 2 ohm RMS, 350W x 2 @ 4 ohm bridged RMS, 1400W Xenith Power
Frequency Response: 10Hz - 40 kHz
Minimum THD: <0.1%, S/N Ratio: >97dB, Damping Factor: >198 @ 100Hz, Channel Separation: >50dB
More information on the amp can be found here: http://www.cadencesound.com/products/XaH175.4.html (please note that the bottom section of "H" improvements don't apply as this is the older Xa model)
General Information
Both items were bought brand new in 2011, they spent their whole life in my Subaru Outback. Unfortunately my Outback suffered massive engine failure so I sold it for parts last month.
Due to the heavy nature of both items shipping is probably not going to be feasible. So both items are available to pickup from my house in Joondalup, Western Australia. If you do really want something posted, you can organise a courier.
You're welcome to test both items if you come up to take a look at them.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
