http://lmgtfy.com/?q=k%26n+high+flow+panel+filter
Autobarn, supercheap, repco.
Most people notice some form of marginal improvement. It is less restrictive.
Im pretty sure i have a panel filter in already, i just assumed they are stock.
Would you say its less restrictive than a pod?
And with panel filters is it true you have to oil them? (people are saying different things)
Edited by kyle345
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6821736
If you have your stock setup you do indeed have a panel filter already installed, not a highflow panel filter (different to stock)
I Needed a new filter not long ago, so I upgraded to a K&N Highflow.
I think I have noticed a small difference, but I'm yet to give it some at a track etc.. $80.00 from Autobarn, just go in and ask for a HIGHFLOW PANEL FILTER for your r34.
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6822171
Thanks mate bought one today for $80
I have to say! I can defs notice acceleration has changed, it feels a bit more torquey and the fact that the filter lasts a life time is great, just needs to be cleaned and recoated with oil.
By far the best thing ive done to my car performance wise
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6822183
I thought that MCM tested this and found that stock > aftermarket panel + pod filters! Ideally something that would simplify your inlet tract so you get less pressure drop from the intake charge would be best
Nah from what ive seen MCM have tested Pod Filters, the reason why you get the drop in power is because they arent getting a constant air feed unless you have it mounted away from the engine down the bottom somewhere, but then u run the risk of sucking up water so its not worth it.
Where as when you have a high flow panel filter, its sitting in your air box and its less restrictive than your standard panel filter.
Your getting a constant cold air feed from the front, ( same as if you were to mount a pod filter in the air box if it fits ).
Personally as soon as i put this in, you can definitely feel a slight difference in acceleration, it picks up a lot better and have this is also supposed to improve your fuel economy because your getting more air through the inlet.
I wouldnt touch a pod filter on a naturally aspirated car
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6822595
from my experience, the difference between highflow panel filters and stock filters can vary between makes of car. the design of the intake and airbox, as well as the filter itself, will determine whether you will get any gains from changing the filter at all. i've change the filter of various cars i've owned over the years. some hasn't made a scrap of difference, others have made a noticable difference (not a huge difference, but you could notice the difference).
  • Like 1
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6823016
To my mind, doing these kind of mods on N/A Skylines is on the same sort of level as V6 Commodore owners putting on underdriven pulleys and plenum spacers. There may be some tiny tiny gain from it, but really you'd just be better off leaving it and saving your money for other hobbies / your next car.
  • Like 1
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6823477
Ahhh the placebo effect. The only flaw in the otherwise very accurate readings of the butt dyno.
Also, getting more air through the inlet doesn't improve your fuel economy. There is a thing called the air:fuel ratio. Getting more air in means you can get more fuel in and hence make more power, but it doesn't improve economy.
You only have to do it every 50,000 miles
Yes. Until reality ruins theory.
Edited by Hanaldo
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6824241
Yeah the perfect fuel/air ratio i believe is 14.7 parts air / 1 part fuel and diesel being 14.5 / 1 but what im saying is having a high flow filter actually increases your fuel economy because its getting a lot more air easily than what your standard filter would. Not saying its a huge difference, but it does. Just like putting in new spark plugs or cleaning them up good.
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6824244
Well that's stoich, but the perfect AFR depends on the conditions. Ie, 14.7 at full load is gonna be real lean.
Again, in theory, yes. You are improving the efficiency of your motor and therefore your fuel efficiency should improve. In reality, unless you had a super restrictive or dirty air filter, just changing the air filter alone isn't going to make any noticeable difference to your economy. Nor will it really affect your power.
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6824292
i have an n/a r34 and i had the normal panel filter before and now i have a pod filter with the stock airbox nozzle giving cold air feed.. tbh same shit. i don't think anything changed, same shit. ohh on windy cold (nights)the pod filter sucks in alot of air.. otherwise same shit. you can do it to make your engine bay look *cooler* if that's your thing, but that's about all that will really change hah :D.
also don't spend your money trying to modify your n/a to make it faster, it's such a waste... 1000$ (with ur own labor- spitfire coilpacks and extractors) will do absolute shit only 20hp, so you realize what a waste it is. as for changing exhaust if you find a cheap second hand exhaust for 200buxs then change it, otherwise... all i can tell you is i got literally one of the best exhausts for my n/a 34 which is a 2.5 kakimoto n1 full exhaust and it's so friken loud, that it makes 113db, and is defectable so badly... and your friends will know you arrived when your a kilometer away... and when you stick the silencer in, your car feels like someone is chocking it. :(
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6824355
Thats why i didnt use a pod, im not one of those p platers that go around "Woah dude check out my new pod! Makes it so much more powerful". Everyone knows how hard it is to actually get a pod to receive cool air, obvs if your doing what your doing is good or sticking it in the standard air box if you can.
Id love a kakimoto exhaust but again yeah im saving money for when i get turbo, thats why im trying to find a cheap pair of GOOD rims cuz atm the previous owner stuck 17 chromies on it..... so idk what to do, im not gonna spend $1000 on rims...
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6824374
Junk the whole thing.
https://www.sau.com.au/forums/topic/423838-r34-pod-filter/#findComment-6824393
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
