So went to the Friday night drifts and was having a pretty good time, car was running well
Was finishing off my 285s and had some stock wheels to drive home on
Anyhow I had a spin which didn't seem all that different to any other times I have had the car spin out on the track over the last few years until I got back on the track and realized something was not right
At 1st I thought I may have popped a tyre as the steering wheel was turned a quarter turn to the right in order to drive straight. I limped off the track to discover that my tyres were ok, however something was very wrong with the back left wheel as you will see in the pics
Pulled the wheel off and had a look, seems like I have bent some rod that has caused the wheel to toe in + also screw up the camber
Put the wheel back on and checked to see that it was not fouling on anything when it turned and that it was tight had no play in it and was not wobbling
Drove the car around the block and it seemed derivable so I went back home at 80kph on the hwy
Surprisingly the car still drives pretty straight, the steering wheel seems to correct the cars direction by moving itself a quarter turn right
Have posted pics of how the wheel is sitting inside the guard
Have also posted a pic of the rod that I think I have managed to bend on the left side along with a picture of the rod on the right side which looks a lot straighrer
Can anyone tell me the name of the rod I have bent and any ideas on what options I have to get this sorted? Might be calling up the wrecker in Victoria that had a few V35s for parts or are there aftermarket items available?
post-9102-0-04199000-1366373115_thumb.jpg straight
post-9102-0-96278300-1366373129_thumb.jpg bent
post-9102-0-37900700-1366373029_thumb.jpg got toe in?
I'm 99% sure its the toe/traction rod/arm whatever you want to call it, I'm hoping that I don't need to get camber arms as well
Now as I am trying to keep the car as roadworthy and defect free as possible dose anyone know what the deal is in QLD about rose joints?
I'm pretty sure years ago when I took my 180sx to the pits after it got defected I had to swap out my aftermarket castor rods for the stock ones as they got knocked back for having rose joints
Had a look at the Queensland transport website but was not able to find anything specific, can probably call them up on Monday to find out for sure but in the mean time if anyone knows
pretty sure that these ones from just jap are rose joints
http://justjap.com/store/product.php?productid=16572&cat=&page=2
these ones on ebay look more like urethane/rubber
http://www.ebay.com.au/itm/Adjustable-Nissan-350Z-Z33-Infiniti-G35-03-08-Rear-TOE-Control-Arm-Bar-Rod-Kit-/271115167760?pt=AU_Car_Parts_Accessories&hash=item3f1fb92810&_uhb=1
I would highly recommend going over the alloy subframe with a fine tooth comb to look for damage.
Check ALL welds and all sections carefully for cracks or stresses.
Also have a think about the arms you put back in; if you use stronger ones they will no longer be the "fusible link" in the chassis and you may destroy the subframe instead.
I had a decent look under the car when it was on the hoist everything appears to be fine
The new toe rods and camber arms were a fair bit heavier than the stock items so I agree with your fusible link comment
Camber arms were fine but I had adjustable ones put in at the same time just in case
