Alright gents, here's a new one for me, from what I've seen on the forums at least. So, I have no spark in any cylinder for all intents and purpose. I pulled out the multimeter and started at the ECU, checking 12V Power from all my Spark Feeds (pins 101, 103, 105, 110, 112, 114) as well as 12V ECCS inputs (pins 49, 58, 59, 109). All were between 12V-13V EXCEPT for 103, Cyl. 2 Spark, which would come in at around 5V-6V occasionally. I went about checking my ECU spark earths (Pins 1, 2, 3, 11, 12, 13) as well as Main ECU grounds (pins 50, 60, 107, 108, 116) and all checked out as earthing for 12V-13V. So, with the exception of one faulty feed, I had 12V flowing from the ECU to the Ignitor Chip, in theory, but when checking the inbound side of the chip, I had no response on every pin that was supposed to be 12V. So...my question is What Gives? Are just my Spark feeds cut somewhere between the ECU and the Chip? Or am I looking at a faulty ECU?
Recap: I have good 12V and earths on all but 1 pin FROM the ECU, but at the plug to the ignitor chip, I have no power.
Attached is the pinout guide I've been using. It says the Grounds are pins 101, 103, 105, 110, 112, and 114, But I'm getting a Solid 12V from them, and a ground at 1, 2, 3, 11, 12, 13 and 10.
https://www.sau.com.au/forums/topic/423859-rb25-r32-unique-electrical-problem/
Which ECU are you using? Which RB25DET - S1 or S2? Because S2 has the ignitor built into the coil, and doesn't need the ignitor box.
Have you checked for continuity (0 ohms) along each of the wires between ECU and ignitor chip?
Series 1 RB25DET with Series 1 ECU and RB20 Harness, Ignitor Chip, Coil harness, and Coils.
00.3 Ohms resistance across all 6 feeds from the ECU to the Chip. But should those be 12V feeds? Because the multimeter shows them as grounds, not 12V feeds.
Alright, final check shows me that at the 3 pin grey plug that goes to the coil harness, as well as the 6 pin plug that goes into the Ignition chip, I don't have 12V anywhere, tested all 9 pins, no 12V feed from the ECU with key On, Off, or Cranking. Am I looking at a faulty ECU hopefully?
When measuring resistance, voltage is irrelevant.
Pins 101, 103, 105, 110, 112, 114 are for INJECTORS, not spark.
In general, the ECU does not supply power to anything, but provides a switch to earth.
By my reading of the circuit diagram, each coil gets power via a relay to pin 2. Pin 3 goes to earth. Pin 1 goes back to the ignitor module, where it eventually gets switched to earth through the ECU. Plus an earth from the coil side of the ignitor (7-wire side).
Yeah, I went through my post and a few more diagrams and realized that mistake. I'm aware resistance deals in Ohms and not Voltage, I first checked all 6 wires from ECU up to the Ignition chip for Resistance (Measuring 00.3 Ohms on all 6) and THEN checked for 12V coming out of any of the 6 wires to the Ignition Chip, and the 3 to the grey plug next to it.
So, you're saying that the earth readings at the ECU are correct, so where would my 12V feed to the ignition chip be coming from?
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
