The cracking the light open was relatively easy.
I took the globes out. And I took all the seals and things covering the globes off. I left the rubber seal along the top of the light was just going to risk it but it was fine. There are several little screws surrounding the light which thread into the poly carbonate take those out as well. Then I put into a preheated oven at 180 degrees and put the hole light in for about 3 and a half minutes. Then pulled it out and with a flat head screwdriver started prying the headlight apart there are some little tabs you need to bend up whiled prying the lens apart. be careful not to disfigure the plastic too much. Once I had broken the seal enough I then proceeded to pull it apart by hand. And all done.
Yet to put one back together. But I plan on flowing the same method. But I'll just put the light in the oven with no lens. Then maybe add a little more sealant in some spots. Then push back together while everything is still hot.
  • 3 weeks later...
Nah front end is in pieces ATM doing a bit of an overhaul. The process of pulling apart and sanding down took maybe an hour. Then paint took 5 mins but drying time I like to leave 2 days. Then 20 min to put back together. Nah no effect to light the important reflector piece is untouched.
  • 6 months later...
This thread motivated me for a little holiday project on my lights, ever since compliance hacked mine up I haven't been happy with the output.
Spend a good 12 + hours today doing the blackout and projector retrofit to my lights. Bought the projectors from the retrofit source and I'm pretty happy with the results. They need some fine tuning (height) but couldn't be stuffed right now, they were pretty fiddely and required a bit of dremmeling of the housing. Fitted my aftermarket HID kit too.
Happy to post some light output shots if anybody is interested.
Cheers,
Adrian
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
