R34 Gtt Direct Replacement Injectors (Need Help)
or poor dump/down pipes with no support and no bellows / flex pipes installed -
I heard their manifolds crack and have seen quite a few stories, or is that usually due to running super hot temps and poor tunes?
Yeah that makes sense. I just thought because there's heaps of fabrication workshops around but I see what you're saying.
Get a 6 boost manifold, a Garrett or precision turbo that will make the power you want, call someone like mobile custom fabrication that can come to your house and do good fab for you. Get a bigger fuel pump and injectors and a modern ecu like haltech or link. Then take the car to be tuned at a shop with a good reputation, I use just engine management in ingleburn
Possibly an old turbo timer.
