Garage Clean Out Turbos 6Boost External Gates
You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
Just went reading. They have a "rotator" air point that the line connects to. Gets mounted to the middle of the rim. And they air up and down while in motion.
Yeah that's what I figured too....that or the compressor gets very dizzy
Hose's can't possibly stay connected from a non-rotating frame of reference that is not on the axle axis. Even if you put some slip joints into the stationary end of it, it would be 3s before it bound up and twisted itself into a pretzel.
