Guys i need input from you gurus as to which way to go with wiring.... I am starting from scratch and want it to be as clean and simple as possible. I am thinking maybe a central Dash mounted panel with resettable circuit breakers and run all the basics through them so I don't have to worry about fuses. Obviously good quality wire and relays.
If anyone has any suggestions please jump in!!
Check out raychem products, you can go all out use their wire, heatshrink, moulded joins, cover the loom in dr-25 etc. where ever you mount the panel it needs to be easy to get to so your not upside down tangled in the cage trying to work on the electrics, resettable circuit breakers are the way to go for sure!
Haha this thread is turning into a 'ask for help' thread. Oh well.
My tuner made some comments about running the Haltech PS2000 ECU i have and wants me to run a motec system.
Super expensive but happy to pay the money if worth it.
What are you guys thoughts???
You might have to search google, I havn't seen a topic on here about their stuff but that doesn't mean their isn't. It's pretty high end to go with their moulded joins, looms covered in dr-25 but very good quality, there might be cheaper alternatives.
With ECUs you could argue all day about what's better but in my opinion it's best to either find a tuner that likes your ECU or use what he recommends
Yeah having a tuner who is confident in the product he/she is tuning is definitely a consideration.
Their products seem interesting, cant find a massive amount of info on it unfortunately but found the Australian distributor so will give them a call!!
  • 10 months later...
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
Hey guys,
IM BACK!!!
So keen to update you all on the progress, lots has happened!!!
Although the car is not finished, it has been coming along nicely and i have done lots of work to the old girl. I will update the thread with photos and details shortly.
Noddy: The car will run a very special 26/30, standard gearbox (for now) and NISMO diff. I just had a little peak at your build, they dont look tooo dissimilar. Woudl be keen to hear how yours goes and think we should pit them against eachother sometime ;)
#skyginer: Yeah the geomerty itself is standard however we have installed every IKEA Formula arm available (roll centre included) bar the front upper control arms which they said wouldnt be back in stock for a long time. SO for this i modified some CUSCO arms.
  • 7 months later...
OK.... Slightly overdue I know.....
We have made quite a lot of progress and I am now going to try and bring you all up to speed..... I am uploading heaps of photos to my PC now so shall do a big post tomorrow!
Cheers,
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
