Hey dudes, i've just started wrecking a maroon series 1.5 R33 Skyline Gts-t in Sydney. The car was running great, however it was vandalized and had some windows broken + roof and bonnet were jumped on. Everything is for sale except the engine
Flick me a message or reply here if you're after anything. I'm located in Sydney for pickup or I can send almost everything anywhere in Oz
More pics will be up during the week !
post-35556-0-49897000-1366709187_thumb.jpg post-35556-0-98449900-1366709221_thumb.jpg
Some aftermarket bits:
Tein type NA damper adjustable sports suspension / coilovers with progressive springs. Great condition - $500 for the full set
Super Spark coil packs, suits series 2 R33 Skyline Gts-t - $250
52mm aluminium radiator & fan shroud, great condition - $150 pickup only
R-tech dished suede steering wheel & HKB hosskit(not pictured) - $100
3" Fujitsubo Giken stainless steel catback exhaust - $250 pickup only
Monsta performance 600x300x70 FMIC & piping kit for R33 Skyline Gts-t. great condition - $250 pickup only
Cusco front strut brace - $100
Adjustable rear strut brace - $80
Chrome Apexi pod filter, bolts right up to most Nissan AFMs - $45
Front castor rods with near new urethane bushes installed - $50/pair
FET turbo timer & wiring loom - $40
5 speed manual rb25det gearbox. Was running great, drove fine with no issues - $1300 ono with tailshaft, shifter, crossmember
I can also sell it as a whole manual conversion for $1500 (with pedals, flywheel, clutch master & slave cyl, etc, etc
Exterior Stuff:
headlights (series 1) comes with HID kit installed, good/clear lenses - $400/pair
s1 front bar & foglights/inducators, has been cut for FMIC - $250 pickup only
s1 front grille (has a small crack in it but it's not too noticible) - $50
S1 front reo bar - has been cut for FMIC - $120
Front guards - $75 each
Bare nose cut/radiator support - $150
A/c condenser/thermo fan - $60
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & matching rear pods - $150
Engine / Engine bay stuff:
Aircon condenser - $120
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $90
engine clutch fan - $60
S2 afm (pink sticker) - $80
standard BOV & crossover pipe - $50
Engine Mounts - $60/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $20
Standard fuel pump - $40
Brakes/driveline:
Front calipers, painted red - $275
Rear calipers, painted red - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $130 pair
Handbrake drum assembly incl cables - $140 pair
Rear differential (4.1) manual diff - $200
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
Complete set of floor mats, good condition - $80
Pair of front seats, good condition apart from a small hole on the driver's side in the usual area - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 150,000km, all gauges working - $100
Instrument cluster dash surround - $80
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
hey dude, do you have the drivers side front splash guard?
It's the bit in the wheel arch that goes from the middle, down towards the front bumper and screws into both the bumper and side of the wheel arch?
  • 3 weeks later...
  • 3 weeks later...
Hey mate, just wondering if you've still got these? And if so, how much posted to Meadows 5251 SA. After the plastic steering column and the little ring that goes around the ignition barrel and key release. I have some already but pretty bad nick. Depending on how cheap, I might grab them, cheers Brenton.
post-96537-0-82857000-1371053645_thumb.jpg post-96537-0-55104300-1371053649_thumb.jpg
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
