Hey dudes, i've just started wrecking a maroon series 1.5 R33 Skyline Gts-t in Sydney. The car was running great, however it was vandalized and had some windows broken + roof and bonnet were jumped on. Everything is for sale except the engine
Flick me a message or reply here if you're after anything. I'm located in Sydney for pickup or I can send almost everything anywhere in Oz
More pics will be up during the week !
post-35556-0-49897000-1366709187_thumb.jpg post-35556-0-98449900-1366709221_thumb.jpg
Some aftermarket bits:
Tein type NA damper adjustable sports suspension / coilovers with progressive springs. Great condition - $500 for the full set
Super Spark coil packs, suits series 2 R33 Skyline Gts-t - $250
52mm aluminium radiator & fan shroud, great condition - $150 pickup only
R-tech dished suede steering wheel & HKB hosskit(not pictured) - $100
3" Fujitsubo Giken stainless steel catback exhaust - $250 pickup only
Monsta performance 600x300x70 FMIC & piping kit for R33 Skyline Gts-t. great condition - $250 pickup only
Cusco front strut brace - $100
Adjustable rear strut brace - $80
Chrome Apexi pod filter, bolts right up to most Nissan AFMs - $45
Front castor rods with near new urethane bushes installed - $50/pair
FET turbo timer & wiring loom - $40
5 speed manual rb25det gearbox. Was running great, drove fine with no issues - $1300 ono with tailshaft, shifter, crossmember
I can also sell it as a whole manual conversion for $1500 (with pedals, flywheel, clutch master & slave cyl, etc, etc
Exterior Stuff:
headlights (series 1) comes with HID kit installed, good/clear lenses - $400/pair
s1 front bar & foglights/inducators, has been cut for FMIC - $250 pickup only
s1 front grille (has a small crack in it but it's not too noticible) - $50
S1 front reo bar - has been cut for FMIC - $120
Front guards - $75 each
Bare nose cut/radiator support - $150
A/c condenser/thermo fan - $60
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & matching rear pods - $150
Engine / Engine bay stuff:
Aircon condenser - $120
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $90
engine clutch fan - $60
S2 afm (pink sticker) - $80
standard BOV & crossover pipe - $50
Engine Mounts - $60/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $20
Standard fuel pump - $40
Brakes/driveline:
Front calipers, painted red - $275
Rear calipers, painted red - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $130 pair
Handbrake drum assembly incl cables - $140 pair
Rear differential (4.1) manual diff - $200
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
Complete set of floor mats, good condition - $80
Pair of front seats, good condition apart from a small hole on the driver's side in the usual area - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 150,000km, all gauges working - $100
Instrument cluster dash surround - $80
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
hey dude, do you have the drivers side front splash guard?
It's the bit in the wheel arch that goes from the middle, down towards the front bumper and screws into both the bumper and side of the wheel arch?
  • 3 weeks later...
  • 3 weeks later...
Hey mate, just wondering if you've still got these? And if so, how much posted to Meadows 5251 SA. After the plastic steering column and the little ring that goes around the ignition barrel and key release. I have some already but pretty bad nick. Depending on how cheap, I might grab them, cheers Brenton.
post-96537-0-82857000-1371053645_thumb.jpg post-96537-0-55104300-1371053649_thumb.jpg
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
