USED HKS RB26 in/ex cam pulley- AUD190 ( will post up pics later, inclusive postage au)
Brand new PROJECT MU HC Titan brake pads. BNR32 ,BCNR33 ,BNR34 (BREMBO ONLY) - AUD250 ( HC Titan ,0-700 deg, top of the line PMU pads, inclusive postage) FRONT PADS
Used RB26 transparent timing belt cover- AUD80 inclusive postage
NEW DISCONTINUED HPI ENGINE DAMPER BNR34/BCNR33 - AUD200 inclusive postage
http://www.flickr.com/photos/classicjapanesecars/8674058773/
http://www.flickr.com/photos/classicjapanesecars/8675159594/
http://www.flickr.com/photos/classicjapanesecars/8401060245/
http://www.flickr.com/photos/classicjapanesecars/8594897472/
pls pm
thank you
Edited by shark79
Hey whats your mobile number ill take the clear cover thanks. Mick
i tried to pm you but it seems you can't receive pm's
here is my email [email protected]
USED HKS RB26 in/ex cam pulley- AUD190 ( will post up pics later, inclusive postage au)SOLD
Used RB26 transparent timing belt cover- AUD80 inclusive postageSOLD
NEW DISCONTINUED HPI ENGINE DAMPER BNR34/BCNR33 - AUD200 inclusive postageSOLD
pls pm
thank you
pls pm
thank you
Edited by shark79
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
