Hi Guys,
I have been having this issue where when I am driving my GTR32 (1992, stock) on the freeway or even suburban roads on a constant speed, the car starts stalling as there is no enough power going to it. When I put my foot down, it takes off like no one's business, which is good...only happens when I put very light weight on the accelerator while drying on a constant speed...
- I have serviced the car and changed the spark plugs, made difference for 2 days and it started again.
- I thought it was over heating, so I completely changed the coolant and it was fine for a day and started again.
- Changed and cleaned the air filters
- Changed the fuel filter and was fine again for a day
- Changed the injectors
The car stalls a bit while driving on constant speed but not as much as it feels like it is going to die.
Not sure what the problem is and I couldn't find anything else on Internet related to this. Maybe it needs tuning? could it be dirty AFM? no consistent fuel vs air? If someone could suggest something, it will be great...
Thnaks guys
https://www.sau.com.au/forums/topic/424064-car-stalls-while-driving/
what rpm do you cruise at?
Has it ever happened when you put your foot on the clutch (and the revs drop) at a set of lights or something?
Maybe when your next service is due, do a de-carb of the throttle body/top end. Most likely not the cause, but no harm done.
Nah, that has never happened.....
if im on low gear and on constant speed, it stalls and can feel it in the cabin....if im on higher gear and cruising on the freeway from 80 - 100kph, it starts and when I accelerates a bit more, it stops and starts again if i take a bit of the load off my foot again...
It is very annoying...
Maybe I will get it de-carb next time and see how it goes....
I was thinking about the coilpacks, but cant be as it only does that on a constant speed...when Im at the lights, its rpm's are fine, no drops in rpm, taking off, is fine too...
dont ever de carb nissan motor, decarb iac but not motor.
Idle Air Control valve, it controls the amount of air that enters the engine on idle, adjusting it for additional loads (Air Conditioning, etc) as well as Cold Starts.
Sometimes it gets clogged up with carbon buildup and doesn't function as it should.
It sits on the back of the intake plenum (it's about the size of a fist) and can be removed and cleaned out with a good spraying of Parts Cleaner.
Thanks heaps trent for the solution...i cleaned it in my gtr32 and it is so much more better now while driving...the amount of carbon/dirt that came out of it was unbelievable!!!! i also cleaned the air sensor for the afm's...damn it feels good driving now....
also thanks to Le-Roy for looking up the post for me...post is for rb20/25, but i got the idea of doing it on rb26...
Hey mate, i dont have a rb26 but i had the same problem with my rb20. I replaced as many things as i could. I cleaned all these parts people are telling you to clean, but after everything i finally found after trying a 3rd afm - it finally went away! Another mate had the same problem and we tried my afm on his car and it made no difference so we tried my crank agle sensor on his car and it fixed it. So basically it is a process of trial and error! But try a few different air flow meters. Hope that helps!
Two things come to mind. The first isn't applicable seeing as you've already stated that the car is stock, and that is - air/fuel ratio problems due to aftermarket atmospheric-venting blow off valves. The second, and this may be a long shot, but your transfer case may be having problems or on it's way out. I drove a GTR (not mine) once which had different size rims front and back (incompetent owner) and it was the weirdest/scariest thing I ever drove. The car would take off fine then the gear stick would jerk back and forward, and even after depressing the clutch and selecting a gear nothing would happen. The car would then stall - turns out he royally f***** his transfer case due to his intelligible wheel selection :O
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
