Hey guys just wondering if anyone could give me some tips in regards to installing a screamer pipe and front pipe on my R33, ive heard all different things such as they leak etc could someone expand on this issiue and give me the do's and dont's for installation? :)
very conflicting question you're asking.
you've already done a big "dont", which is buying a screamer pipe in the first place.
it will probably sound like a tractor on idle.
cops will love it. (not really)
pulling up to a car with a proper external gate to atmo and you will feel kinda ghey.
keep an eye out for a 3.5/3in dump pipe for when you get sick of it/defected :)
on the other hand, if its made for an RB it will most likely bolt straight on to your turbo/cat.
  • Like 1
Customer had one and it also cause the turbocharger to boost creep from a tight divider in the center. Which's apart of the reasons that his turbocharger came in for high flowing with no turbine wheel. I need to get one of those for mine to run 30psi on.
I have also seen result of cars losing torque on a dyno when they have a screamer pipe compared to their plumbed up split pipe. Car sounds like arse and you lose torque? Sounds like a shit mod to me. May aswell instal an RB20 while your at it.
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
