$6000
Regretful sale of my Nissan Skyline R33 GTSt.
Need a learner car for my boy to learn in hence it must be sold :(
IMPORTANT: RJ0085 PLATES DO NOT COME WITH THE CAR, NEW PLATES ARE ZRS-057
Vehicle located in Lilydale - VIC 50 minutes east from the city.
Inspections available evenings or weekends -
0427 234 192/[email protected]
Will consider a swap for a reasonable ute
Details:
Registered until August 2013 - buyer MUST organise own roadworthy within 14 days.
154000kms
5 speed manual - slight input shaft bearing noise at idle(clutch not engaged) on occasions. Shifts & drives well.
Turbo - good condition
Mechanically sound & unabused unlike a lot on the road these days. Very smooth & enjoyable to drive
Genuine GTR wheels with good condition Bridgestone RE001 tyres. Hard to find 17"x9" wide
Brakes are good
Cat back exhaust - smooth sound
Front mount intercooler(black) - has a tidy cut in driver's side guard for intercooler piping
HID headlights
6mth old good condition windscreen - new wipers
Series 2 spoiler
Carbon fibre vinyl wrap two tone look. Looks sharp & original
LED white parkers front & back - cleaner look
Has a standard air box but comes with the pod filter setup if wanted, took it off due to inter-cooler/turbo sound on decceleration
ADR/Insurance approved black wiring Mongoose immobiliser with automatic 1 minute turbo timer, installed August 2012
Kenwood phone/bluetooth/MP3/iPhone/USB head unit with FOCAL Splits in front & 6" rear parcel shelf FOCAL speakers
Don't think it needs much for a roadworthy, maybe exhaust & cut in guard for FMIC, depends on RWC guy - very good condition all round
Interior is immaculate with freshly replaced leather gear stick & park brake boots & original Skyline mats. Looks as if noone has ever sat in the back
Service Items Performed in the last 6 months
Oil & filter change 3000kms ago
Martini Racing brake fluid change Dec 2012.
Timing belt, water pump, cam shaft seals Dec 2012
Upgraded alloy radiator & coolant change Dec2012
2nd Australian owner
Things to pick on:
Tiny dimple dent on front guard
Where front bumper meets front guards & rubs very minor treated rust
As per photo light scuff on back left of bumper
Front bar is scuffed & has an average repair since before i bought it where it is closest to the ground in central area not all over.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
