hey guys my 1994 r32 GTR is up for sale at a good price, the car is in very good condition for a gtr, the car has NO oil leaks, no rust, does not blow smoke and starts first go everytime. i was gonna keep it and build a real quick street car but other plans have come up and im gonna be buying a house so this has too go
1994 r32 gtr in silver
car has done 134 xxxkm
modifications:
twin pod filters
blitz blow off valves
r34 gtr ball bearing turbo
3inch jasma front pipe
3inch kakimoto exhaust (stock exhaust is on the car)
turbo timer
blitz electronic boost gauge
short shifter
the car has had a full major service, new spark plugs, castrol edge professional engine oil, fuel filter changed, gearbox front diff and rear diff full synthetic valvoline oil, brake fluid flush, coolant flush u name it every fluid has been changed.
bad points of the car:
all 4 tyres are bald, it needs brake pads, tear in drivers seat but thats a common problem, thats all i can think of.
i can organise to get that all done at an additional price.
car does not come with RWC or REGO, i cancelled the rego cause like i said i was planning to build a street car and knew it may take a while.
selling for $12,000 CASH SALE ONLY!
located west victoria, contact me on 0411967002 i can mms more photos if u like
i will be updating the photos or details if i find anything else.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
