Hi all,
Thinking of taking a change in direction for my build. I have the following which I've been hoarding.
1. Ppg helical 1-4th dog engagement with billet main shaft. Minimal Km's as RB's don't last long :)
http://www.ppgearbox.com.au/page.asp?productid=59 $7000
2. Os giken 5 speed gearset. Little use, same story Box outlasted new motor. Assembled by award diff $5500
3. Jim berry fullmonty single plate used $1500
4. Nismo twin plate copper mix used $1500
5. Spare rb26 bottom end (short) - machine work carried out by Duncan and foster
87mm cp pistons (500kms old) I beam forged conrods with arp bolts new rings bearings main studs
$5500
6. Complete head ready for porting if need be... I have a rb26 spare head with complete supertech valvetrain kit (dual springs retainers valves) bronze guides, tomei camshaft 260s 10.5lift ready to assemble, just deciding whether to port or not. Responsibilty is with powertune $4000 without port work $5k with
Parts can be picked up or inspected at Profab or powertune in Sydney
:cheers:
1. Os giken 5 speed gearset. Little use, same story Box outlasted new motor. Assembled by award diff $5500
Price Drop $4800
2. Jim berry fullmonty single plate used $1500
Price Drop $1200
3. Nismo twin plate copper mix used $1500
Price Drop $1200
4. Spare rb26 bottom end (short) - machine work carried out by Duncan and foster
$5500
Price Drop $4800
Will bundle if interested.......
  • 1 month later...
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
