TIme to clean up the garage.
All items can be picked up from the Sutherland shire Sydney or Blacktown.
RB20det engine complete with CAS, Loom, ECU,ignitor, injectors, Coil packs, clutch/ flywheel, manifolds, turbo as seen in the photos. $1400ono
perfect for a conversion.
Come out of a 93 r32 gtst with 130xxxkms. removed by me to make way for RB26.
Compression tests are fine and i took a video of it running before removal.
Rb20,RB25 s1, RB26 Splitfire coil packs, literally brand new and used for 5 minutes $480 firm
Rb20 manual gearbox good condition $450ono
Rb20 starter motor $50
Rb20 alternator $70
Rb20 standard coil packs good condition $150ono
R32 GTR fuel pump $80ono
Rb20 Afm $40
R30 new engine mounts x 2 $60
Rb20 timing belt kit with pulley/ new bearing, seals, timing belt $80
Rb20 water pump near new $80
R32 gtst radiator $80
Call rob 0418 686 96two
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
