4 x 17" V35 rims - rears are 17x8 +33, fronts are 17x7.5 +30 - 5 x 114.3 PCD & 66mm centre hub. These are the OEM rims off a V35 350GT non-premium coupe, but will fit many other models.
plus
2 x Toyo Proxes R1R 235/40ZR17 road-legal semi-slick tyres, fitted to front rims but not to car - never been used
plus
2 x Toyo Proxes R1R 245/40ZR17 road-legal semi-slick tyres, fitted to rear rims but not to car - never been used
The rims are in pretty good condition. They had a little bit of rash on the outer lips when I bought them, but I sanded it back & touched them up with a brush - they were track rims so I wasn't too fussed.
The tyres were bought brand new earlier this year, then fitted to the rims & balanced, ready for hillclimbs & track days this year. I haven't had a chance to use them yet, so the tyres haven't even been on the car. On an impulse I've bought an Akebono big brake kit, and the 17" rims won't fit over the front calipers - my loss can be your gain.
If you plan to hillclimb or track your car, these tyres will give you a huge advantage over street tyres.
I'm after $1000 for the lot, ready to bolt onto your car & go to the track. If there's no interest in these as a package I will consider separating tyres & rims, and also selling the tyres in pairs. I bought slightly different sizes because the V35 has a staggered fitment, and wanted to maintain that. The sizes I have are a lot closer front-rear than the stock sizes, and I would be happy to run them on any non-AWD skyline.
Interested - reply here or call me on 0418 841 730. Pics available if required. Pickup only from Golden Grove SA. Perfect for the SAU SA track day:)
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
