1993 R33 GTS-T Custom Metal Flake Paint, 225+rwkw, Tested 140db Stereo System. Genuine 12second car! I unfortunately have to sell due to an expanding family.
Has made 224.8rwkw as auto since then has had a manual conversion and upgraded fuel pump so should be at least 240rwkw!
Exterior: -Custom coarse metallic and anodised metal flake respray in gunmetal grey 6 months old has to be seen to be fully appreciated -M sport front and rear bar -Drift wing -Clear indicators side and bumper -Lenso op2 20inch wheels -rear debadged
Interior: -kenwood head unit Bluetooth 3 sets of RCAs inputs - trust chrome gear knob - autotechnica steering wheel - legend of sound stream 6.5inch coaxials in doors - soundstream 6x9inch - kicker cvr 12inch subwoofers in custom sub box - 4 channel fusion digital amplifier 4x150watt rms - mono block kicker 1000watt rms -1.5farad capacitor - soundstream 700cca car audio battery Very loud system, not many like it around.
Performance: - large front mount intercooler - pod filter - turbo smart dual stage boost controller with hi/lo boost switch in cabin - turbo smart blow off valve - nistune ecu - greddy adjustable cam gear - walbro 255lph fuel pump - turbo smart turbo timer - 3 inch turbo back exhaust - running 14psi boost on standard turbo so minimal lag!
Transmission: - r34 gtt 5 speed gearbox - braided clutch line - exedy heavy duty clutch
Has run a 13.4 as an auto and a 12.9 as a manual in the quarter mile. Is definitely capable of a mid 12!
Serviced every 5000 km with only quality products used. Will come with a few extra bits like a turbo smart boost gauge and some track wheels. This is a beautiful one of a kind car. Drives great as a daily and has plenty of power but not over the top. please no time wasters or joy riders. The stereo will now come included in the price as I need it gone due to my expanding family. I will consider any reasonable offers! Created on Carsales Mobile
https://www.sau.com.au/forums/topic/424120-r33-skyline-4-sale/
  • 2 months later...
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
