1993 R33 GTS-T Custom Metal Flake Paint, 225+rwkw, Tested 140db Stereo System. Genuine 12second car! I unfortunately have to sell due to an expanding family.
Has made 224.8rwkw as auto since then has had a manual conversion and upgraded fuel pump so should be at least 240rwkw!
Exterior: -Custom coarse metallic and anodised metal flake respray in gunmetal grey 6 months old has to be seen to be fully appreciated -M sport front and rear bar -Drift wing -Clear indicators side and bumper -Lenso op2 20inch wheels -rear debadged
Interior: -kenwood head unit Bluetooth 3 sets of RCAs inputs - trust chrome gear knob - autotechnica steering wheel - legend of sound stream 6.5inch coaxials in doors - soundstream 6x9inch - kicker cvr 12inch subwoofers in custom sub box - 4 channel fusion digital amplifier 4x150watt rms - mono block kicker 1000watt rms -1.5farad capacitor - soundstream 700cca car audio battery Very loud system, not many like it around.
Performance: - large front mount intercooler - pod filter - turbo smart dual stage boost controller with hi/lo boost switch in cabin - turbo smart blow off valve - nistune ecu - greddy adjustable cam gear - walbro 255lph fuel pump - turbo smart turbo timer - 3 inch turbo back exhaust - running 14psi boost on standard turbo so minimal lag!
Transmission: - r34 gtt 5 speed gearbox - braided clutch line - exedy heavy duty clutch
Has run a 13.4 as an auto and a 12.9 as a manual in the quarter mile. Is definitely capable of a mid 12!
Serviced every 5000 km with only quality products used. Will come with a few extra bits like a turbo smart boost gauge and some track wheels. This is a beautiful one of a kind car. Drives great as a daily and has plenty of power but not over the top. please no time wasters or joy riders. The stereo will now come included in the price as I need it gone due to my expanding family. I will consider any reasonable offers! Created on Carsales Mobile
https://www.sau.com.au/forums/topic/424121-r33-skyline-4-sale/
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
