Part: BNR34 Skyline GT-R Wheels
Condition: Has gutter rashes and scratches, but structurally fine with no balancing issues. Original paint too as far as I can tell. Tyres have 50+% tread.
Description: Set of four R34 GT-R wheels including centre caps, 18x9 +30 with Falken Azenis tyres (265/35/18)
Contact Details: PM
Asking Price: $1,500
Pick-up/Postage Arrangements: Pick-up only.
Other Comments: Came off my R32 GT-R. With a bit of negative camber I had no scrubbing issues. The tyres grip rather well, they impressed me in the wet.
Tyre fitment:
https://www.sau.com.au/forums/topic/424124-nsw-r34-gt-r-wheels-with-tyres/
Really not a bad price when you consider that 265/35/18 can be used on a 9.5" or 10" rim too!
...and then if you're in Sydney, ask Luke_GTR to do a discount tyre swap if required.
Rims are made by BBS & are light weight.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
