Make/Model/Badge : Nissan Skyline R33 GTR
Year : 1996
Colour : Deep Marine Blue
Selling Price $ : 21,000
Odometer Reading : 90,000
City : Melbourne
Rego :XII 597 - Reg until November
Imported in October 2009, this car has been a dream to own. All I have ever need to do to it is service it and fill it with fuel.
Major service completed less than 10,000k's ago. Serviced every 5000 km's. Service history since owning the car. Just completed 90k service.
Current power figure is 220awkw @ 0.9 bar.
Nismo LMGT2 18" wheels with very good rubber. (18.275.35 Rear, 18.245.35 front)
Greddy Profec Boost Controller
Trust Turbo Timer (Auto and Manual Settings)
HKS Dump Pipes.
Jazma SR Exhaust System (Removable Silencer).
OHLINS Adjustable Coilovers.
Nismo Centre Gauges.
ULTRA Speed II Speed Meter. (Measures Trip, 0-100km/h, 0-400m).
Pioneer Head Unit, Kenwood door speakers, tweeters and 7x10's.
Alarm/central locking.
Climate control is working perfectly. Icy cold air-con.
2 sets of mats. (Original GTR mats as well as rare Nissan Prince factory optioned mats)
Immaculate interior and paintwork. Car has undergone a full detail.
Price is negotiable. Roadworthy and / or Reg is optional.
Please PM me if you have any questions or would like to arrange an inspection.
Pics:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
