Wtb: Rb26Dett Stroker Kit + N1 Block + High Vol. Oil Pump
Hi...I now live in the Philippines, Manila
A friend of mine in Brisbane ATOMICBOMERMAN....Chris Wong 0417755890 is going to help me sell off my gear for GTR's etc
The gear is in storage in Brisbane
Please make a list and contact him.
New N1 block in box
APEXI SPL 2.9 full counter stroker kit
a Complete N1 block race Engine Built by JHH Engineering in Brisbane with full counter Bottom end...block modified to suit raceing...top and btm stud kits. Heads fully ported and flowed...both intake and exhaust valves are oversized...bronze guides etc...TOMMEI oil pump, cm gears etc...HI Octane sump, Quaffi diff, 4.6 group A diff gears...Hypertune intake, throttle body, fuel rail....list goes on...they have pictures on their Facebook site of the Engine etc
OS Giken gearbox....5 speed with shaft...rebuilt late model box...never used
Numerous turbo kits...even a new Greddy TD06 or TD05 full twin kit, 70 plus parts to this complete kit...manilod was ceramic coated.
I have twin low mount kit too and there is a single as well
Have ARC twin entry intercooler...ARC radiater...
Rims...twin carbon clutch...APracing and Greddy brake kits....whatever u are after it will be there Ti exhaust for 33...more and more
[email protected]
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
