Up for sale is my Greddy Multi Switching System. Wires were run in the car but never connected or installed
Selling due to going for a ECU upgrade that can handle what this switch was intended for.
These products are discontinued and becoming rather hard to find, Bonus as this is as new!
A bit of info on the switch: GReddy Multi Switching System (MSS) is a two-channel programmable general output controller.
Can be mounted anywhere into the vehicle and directly wired to the ECU harness so things like Nitrous, Cooler sprayers, or Solenoids to name a few. Each channel is activated through one, two or three parameters such as RPM, speed, temperature, boost or any other analog signal. There is also a extra Relay Kit available online you can activate fuel pumps, electric fans and other higher drawing items. The multi color display can also monitor the inputted signals for peak-hold and warning values.
Breakdown of features:
  • Two separate outputs for switching (on and off) electronic devices such as solenoids, IC sprayers, warning lamps, thermofans etc
  • Each channel can be prgrammed through one, two or three parameters such as RPM, speed, temp, boost or any other analogue signal
  • Multi coloured display can monitor signals for peak hold and warning values for input signals
  • Cockpit mounted and can be wired in to ECU signals or external sensors
Item will be posted via registered post.
Price is $250 delivered anywhere on the Eastern Seaboard. Sorry SA and Perth :P
pics.
https://www.sau.com.au/forums/topic/424188-greddy-multi-switching-system/
