Hi guys! My name is Joey and I am from Canada. I have a BCNR33 and have just done a few modifications to my car and it has running issue....
Specification:
RB26 stock head stock cam
Tomei 2.8 stroker kit bottom end
Injector Dynamic 1000cc + injector resistor pack deleted
Ebay twin entry fuel rail + stainless braided hoses
Tomei intank fuel pump + Type L regulator
Apexi' power FC + datalogit
Stock AFM
Stock turbo
Autobahn88 intercooler
Stock recir BOV
The engine was rebuilt about 500km ago and have good compression, if not perfect. Timing should be perfect as I never touch it
I have replumbed the fuel line myself and it gets very good and stable fuel pressure
So right now I am using a default setting on my FC and I set the injector to 44.4% and +.228ms. The car has difficulty starting and eventually it can idle at about 400~450 rpm and my wideband shows about 12.8 during it's idling. When I step on the throttle it stalls. So right now I don't know what to do.....I would hate to remove all the work I did and revert back to the stock ECU and stock injector.....
I would like to know what I should start checking or what could be wrong? Can it be my spark plug gap? but then it can sort of run.....
Really really really appreciate anyone input into my sitaution! Thanks again!!!
Fuel plumbing bcnr33 by Komachi1, on Flickr
Edited by Komachi
https://www.sau.com.au/forums/topic/424195-rb26-id1000-power-fc-setting/
Thank you!!!!! One more question...if I want to set my base pressure at 4 bar...for whatever reason it is, I use the flow rate and battery voltage deadtime data at 4 bar in the chart and my car should run the same?
yeah, ooh and dont forget ID's love high base pressures.... its not uncommon to have 70-90psi base pressures even on NA cars.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
