Rb30 Carb To Efi Conversion
By drifter17a · Posted
I should video mine, will prob do it tomorrow Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is horrible:( -
Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster. -
Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive. -
Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
