Name/Contact : Zach / Pm me on here
1. Precision 6262 Billet Turbo - Brand new
- Antisurge comp cover, Billet wheel
- Rated at 705hp, comparable to gt3582r but flow more and spool a bit sooner
- T3 .82 V-Band rear
- I will throw in the genuine clamp and V-band flange which cost me $120
- http://www.precisionturbo.net/Street-and-Race/ss/600-800HP/details/Street-and-Race-Turbocharger---PT6262-CEA®/245
$1000
2. RB26 throttle bodies
- Removed from my gtr when I upgraded plenums and changed to a single T.B
$200 - Make an offer
3. RB26 HKS metal throttle body gaskets - Brand new
$40
4. RB26 fuel rail
$10
5. RB26 HKS Log low mount manifold
- T4 divided flange
- Has elbow to suit HKS wastegate
- Has cracks that have been welded
- It had a garrett TA45 turbo mounted and there was plenty of cleanance
$150 - Make an offer
6. VL turbo/r31 RB30 original crossover pipe
$20
And I know it's Toyota stuff, but I'll throw it up just in case...
7. 2JZ stock twin setup
- Came on a motor that I was told was running, when I pulled it down the front turbo doesn't spin freely.
$200 - make an offer
8. R154 Gearbox with JZ bell housing
- Comes with shifter, master cylinder and elec speedo sender
- Rebuilt by Status Gearbox and Diff, has not been used since rebuild
- There was nothing wrong with the box, I just wanted it like new, all genuine parts, new syncro's, bearings, seals, gearsets and forks inspected
- Has a Marlin Billet thrust washer
- No headaches of installing a second hand box and finding its worn or doesn't work properly
$2700 (Can provide receipts)
9. 2JZ 6boost high mount manifold - Brand new
- T3 open flange
- Comes with studs, gasket and steam pipe elbow if needed for the gate
$1200
Also have a heap of other stock 2jz stuff like cams, cam gears, balancer, water pumps, oil pump ect.
Edited by zachscalais
  • 9 months later...
