sold the car , doing garage cleaning
Blitz Dual SBC boost controller - 200$
Blitz super suction filters pair (new) - 100$ both
Nismo Gmax Twin plate clutch blue one pull type (lots of meat on it 3.4mm) - 400$
Exedy Single clutch 400whp rated - 150$
Nimos fuel pressure regulator (new) - 150$
RB26/25 oem oil pump New - 150$
Z32 Mafs pair - 180$ both
Rb26 greddy type turbo suction kit chines one with two filters - 150$
Rb26 R32/R33 gtr apexu PFC with hand controller - 600$
r32 GTR - ecu 100$
Borg warner S200 Turbo 48mm/60mm 50ar/83ar Twin scroll T4 new - 400$
Wilwood 6pot SL6 big brake calipers with new pads (no brackets) - 450$ both
Wilwood 4pot big brake kit new with new pads good for rear on gtr-s - 300$ both
r33 GTR NIsmo 320km/11k rpm cluster black fase - 350$
Defi Din gauge, white face oil/water temp, oil pressure (missing just power wire ) - 400$
Tein Circuit Master coilovers - R34 GTT , R33/R34 GTR , needs rear spherical bearings 100$ for pair (10k kms done on them) - selling 600$
this is what i remeber should be more need to take a look , pictures will be uploded later
Note - all these parts are located in Georgia payment method Paypal , shipping will be Fedex or DHL , last time sold apexi ecu here took 60$ shipping to Australia , so its better for me to do combined shipping
can do shipping world wide
prices excludes shipping
taking offers
Chirs
Dato
https://www.sau.com.au/forums/topic/424236-r33-gtr-rb2625-stuff-all-kind/
Wilwood 4pot big brake kit Rear..... just checking if they are just for the gtr-s or will they fit GTR/BCNR33? if yes, than I will take them if not, oh well. send message either way. :cheers:
Edited by JadeGTR
taking offers
Chirs
Dato
Hey mate, got any pics of this set up? How much posted to oz?
Thanks, Dave.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
