Hi guys, i have just picked up a R34 Gtt (auto) and it seems to take a while to get to boost. Could a few of you let me know what RPM your standard turbo 34's start to make positive manifold pressure so i can see if mine is the same or not, at the moment it doesn't become positive till around 3000rpm and i am wondering whether theres a leak or if thats normal.
Don't forget with an auto the transmission is not always directly engaged with the engine, so what rpm postive pressure comes depends largely on how much throttle you are applying. Don't expect much boost with the stock auto boost controller anyway.
Edited by sonicz
Its 1.1 kg/cm well thats what it says on the apexi but its not getting that high .As i stated in the original post i just got the car, it looks like the standard turbo as all the stock piping is coming off the outlet of it.
Ok even though my car is pinging, I set my car to stockish boost and took some dodgy videos to show you how the automatic transmission and throttle is the biggest factor in what RPM an the car develops positive pressure.
In D, on snow start setting, full boost can come as early as 2000rpm. In L setting, gear one, and "power" setting the engine may reach around 5000rpm before the gauge show you full boost. It Depends on how much throttle you give it as well. 3/4 is different to full.
Unfortunately I am capped so it will takes ages to upload
What are you reading the boot pressure off? Just to let you the stock boost gauge measures in mmhg (millimetres of mercury) and not psi.
Edited by sonicz
reading boost off the apexi avcr and the stock gauge. just thought around 2800-3000rpm was a little late to get positive pressure. Thanks for the video sonicz
Edited by jase_c
There's no point talking about boost threshold unless you're talking about 100% throttle and a high enough gear to get sufficient load into the engine to get the exhaust flow up.
1st gear and even 2nd gear are a waste of time. 3rd or 4th in a manual or whatever you can achieve in an auto without it kicking down too many gears.
adjust the tune to bring boost on earlier (more timing)
1.1kgmc2 is too much boost for standard turbo
auto runs different diff gears to manual so gearing would play a part (engine load / turbo charger boost pressure ramp)
auto also runs different stock boost actuator (irrelevant when using boost controller)
imho tune your ecu setup and you should be around the equiv of a manual ish
from memory in my manual 33 tuned i had 0.85kgcm2 by 2700rpm
Thanks for that info mate, the car has a greddy emanage ultimate setup and i have it booked in for a tune in 2 weeks so will know more about whats going on then. I am starting to think the stock turbo may have been hi flowed or something for that boost.
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
    • The prices of NCs are going to go up thanks to you... and partially the MCM guys.
