OK the car is a 2008 GH Series Mada6 but the principals should be the same.
I've got the kit, the fluid etc, but I just want to know if it's considered safe to remove the drain plug, let fluid drain out (after warming it up) and then start the car and let the box pump out the remaining fluid.
My question being, is there any chance of damage or airlocks etc by doing this?
Or is it better to just drop the drain plug, let it drain, drop the pan, replace the filter and whatever fluid comes out and nothing more then drain it again in say 1000k's and put in more new fluid?
I do my own mechanical work so I'm comfortable with the process just can't find anything concrete on this particular car. My Falcons wee fine to just idle and pump out the old fluid.
I'm assuming that if I drop a cooling line and let it pump out additional fluid (without having a proper flusher connected that's feeding in new fluid) that I run the risk of airlocks or damage?
Edited by ActionDan
https://www.sau.com.au/forums/topic/424256-auto-service-questions/
I'm done, here's what I did.
Warmed it up, pulled the drain plug and let it drain, about 3L came out (I emptied the oil pan into a container with measurements so I knew how much was coming out).
Put 3 fresh litres in and warmed it again and shifted through all the gears and various speeds (car up on stands completely so wheels free to move), dipstick level was good, but fluid still average looking/smelling.
Dropped the drain plug again and let it drain, then dropped the pan and replaced the filter, about 4 or so litres came out this way - though keeping in mind some of that was new fluid.
Cleaned up the gasket surfaces and re-assembled it all. Noted that the bolts had thread sealant on them so used some medium Loctite (pretty easy to remove).
Refilled it, warmed it, shifted through all the gears then check the levels and looked for leaks, all good.
Took it for a good drive, came back, checked level and for leaks again, all good. Put undertray back on and cleaned up.
Fluid is now a much nicer red and smells better. Trans didn't seem to behave any different, which is good I'd say.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
