used to be a once a week shaver. One month @ Kappoka changed that.....
Think I need a new saftey razor, at times when i shave the head becomes a little loose and I have to tighten again. Probably not the best thing if the blades are wobbling around
need to venture out of wasteland more. great thread.
currently using shick quattro from the jawline down. wahl trimmer for the rest. I find it best to jump out of the shower, dry off and get to shaving, especially because my facial hair has a whorl on my right cheek and every direction is against the grain lol.
19 year old baby-faced, non-frequent shaver checking in.
Welcome, from a fellow baby-faced once a week shaver (stubble trimmer, to be specific :P)....however I'm 25 next month LOL
Ma man! I shave once a week- fortnight depending on mood. By the end of the fort
Night, I'm just reaching the itchy stage. :P
Just using a Mach III at present but have always wanted a proper razor and didn't know where to start. This thread helps heaps. Thanks heaps for all the info everyone!
It's just your face man, you can grow another.
When your putting a blade to your face it just doesn't seem as easy as that lol
Go slow and don't push too hard lol
OK, gave it a crack yesterday. It's much harder than it looks!
I used the following;
  • Merkur 34c
  • Astra Stainless Blade
  • Omega Badger Brush
  • Proraso Sensitive Shave Soap
  • Ceramic bowl for lather
The Merkur - I liked the look of it and it was pretty easy to load with the 2 piece design.The weight was good, not heavy and not light, felt well weighted. But its very short compared to the normal Gillette/Shick commercial stuff so it felt a little uncomfortable in the hand at first. I think it will take some time getting used to the small handle, especially after years of long handle use.
The Astra blades I cant really comment on as they were the first I tried. Not as sharp as I thought but my technique is crap so cant blame them just yet.
The soap - struggled to get a good lather using a bowl but probably not the soap but just me again. But the soap left my face feeling very dry afterwards and really had to use a balm to 'moisturise' it. I'll try the cream next as not keen on the dry feeling it left afterwards.
First impression of 'wet shaving' - its pretty hard! I knicked myself a fair bit (probably 3 or 4 bleed spots!) but my growth is very tough and combined with not the best lather and poor shaving technique it was bound to happen.
Now I realise why this isn't for everyone. Its a lot of effort to shave with so much to do and it feels like starting all over again. The technique is completely different to your Mach 3 shave and it takes longer.
But shaving now seems like more of a hobby now and almost fun as opposed to a chore and that is what I think makes this appeal to many people.
My wife laughed and me and said its a lot of effort for a shave when you have to do it all again very soon... hhmm. But I'll stick at it and get better!
I was the same first time around, couldnt get a good lather. I thought it was the cream but it was just my technique.
Now with the smallest amount of cream I can get a good lather which will last for 3 passes and then some. As you practise you will find your trouble areas and you will know how to change your style to get a good outcome.
My last shave was perfect and only took 5 mins :)
It will just take you a few goes to get used to it.
great report! =)
How do safety razors go with facial irregularities?
I have a fairly small mole type thing on my lip (think about pimple size thats ready to blow)
Would i be likely to take the top off every time i shave?
Cartridges seem pretty good at just flowing over the top of it with no drama.
Not sure on the mole thing but I guess a razor is a razor, if it doesnt cut with the normal stuff it shouldn't cut with the safety stuff either.
I'm getting a decent lather now that I have worked out what is too dry and too wet.
Also the blade makes a massive difference, the feather literally sliced me everywhere, where as the son of rajab was sharp enough to cut nicely but not tear your face off.
Bought some pre-shave oil from Somersets just to aid with the process. Seems to have helped a little.
Edited by SRS13
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
