lol fking Adam's apple, I have a really sharp Adam's apple and it's pretty much a magnet for cuts / razor burn. There's no easy way about it with the DE. Cartridge gets it fine though.
I've also started playing around with the adjustment of my Feather DE pole...I'm not sure how adjustable it's meant to be, but you can give it an aggressive setting by not tightening the blade as much. The blade feels flimsier, so have to do it carefully, however you can get a with the grain shave almost as close as against the grain.
Agree re: side pass. It's good, especially for cheeks...what bothers me though is knowing that if I do an against the grain after a side pas I'd still pick up a heap of grain lol
Nervously broke out the Dovo shavette last night for my first foray into cut throat shaving. Really thought I was going to walk away with a face full of blood, so decided to just stick with cheeks.
Well, after them, I thought I'd try the side of my neck...before I knew it, I had done the whole face. Seriously the most comfortable shave I've ever had! It may help that I spent half an hour doing it so as not to slice myself, but I think all my time with a DE safety had helped me transition to this, as aside from holding the handle completely differently, the same rules applied (angle + pressure). Not a single nick, just one or two red spots from against the grain strokes. This was also using just king of shaves kinesium oil and Gilette foam, no real shave soap or prep. Definitely sticking to the shavette, and touchwood it wasn't just beginners luck.
There's hope for me getting a traditional straight razor yet!
straight razors are fun to use.
I am still getting use to mine, mainly with my left hand. But with each shave I am nicking myself less and less.
will need to get a new shaving cream as my stuff from America is running low so i'll be on the hunt for some knew stuff.
Any recommendations?
Might be some good stuff on mensbiz?
I can't recommend anything as I haven't tried enough, I just go off the mensbiz reviews and buy stuff with a minimum 4 stars...that seems safe to me.
If you're talking off the shelf I always swear by Nivea's gel. Currently using Gilette Fusion gel and it's not bad.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
