Hi guys,
I've been reading over various threads but finding conflicting info and no definitive answer on this one...
What is clearance like for a 25/30 in an R33?
My understanding is a 25 sump, 25 inlet manifold, 25 engine mounts will drop in and fit, the bonnet will *just* close and you have no hope of running a front strut brace.
Other options are re-drilling engine mounts (does the drilling happen on the block mounting face?) to lower the engine, how low can it go before hitting swaybar, will this allow a strut brace to fit, and does this angle impact much on driveline lifetime/reliability?
Or, fit a greddy style forward facing plenum with stock engine mounts, will this allow a strut brace to fit?
Cheers lads!
https://www.sau.com.au/forums/topic/424287-clearance-in-an-r33/
  • 1 month later...
  • 6 months later...
I just ran vl/r32gtr engine mounts in my 33 problem easy solved. well sorta, also used 14mm alloy bar to space the gearbox down so there is no funny angles an the bottom part of the fan shroud was removed cause fan was hitting, but that's it clearance is perfect an I am running strut brace an all with heaps of room using a 26 head also
i have a r33 fitted with the rb20e motor.can i use my stock mounts on the rb30.will the engine need to be lowered on those mounts if keep the stock rb25 manifold
Measure how much clearance you have now. rb30 deck is 38mm taller.
