I can assure you, from experience (at QR yesterday), plummetting down the straight and feeling your brakes not gripping the rotors is not a fun feeling.
Nah the brakes worked but the pedal was sinking to the floor when hot. couple of cool down laps & they were sweet again.
  • Like 1
Exactly the same problem I had... Looked it up and it's caused by the fluid boiling. 3 remedies are: Titanium shims behind the pads, Better brake fluid, braided lines.
Oh and to make matters worse, once it's boiled once, it's more likely to boil again :(
Motul RBF 600...get it. I have never had brake fade on QR and I go HARD on all the straights every lap, no cooldowns for my baby :P
I also have braided lines, but they don't help with cooling just give a better pedal feel as they don't expand under pressure.
Apparently braided makes a bigger difference when the fluid is hot :) Have you tried the motul rbf660? Any idea if it's compatible with my car?
Well heat makes rubber more pliable so it would expand more when the fluid is hot. The 600 and 660 are about the same, except the 660 boils about 20 deg. higher and costs about twice as much. Just use 600, more than enough as your pads will give out before you boil fluid (assuming they are just street pads).
Hmmmm I can get 660 at a *reasonable* price... I don't wanna change it twice if I upgrade other components later... Argh... I dunno, I might be over-thinking this...
I can't make this and I needed to cause of work, so can you guys do me a favour please. Can you ask what settings to run for 50% street 50% track.
Castor
Front camber
Rear camber
Rear toe
What ever else that can be adjusted please on an alignment place. Thanks.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
