So ive noticed that when Im steering at really low speed I tend to get a clunk sound as if there is play in the steering and its starting to get my interest. Steering feels fine, no real issue there but the clunk has got my attention as its annoying. Anyone have this problem? Fixes?
https://www.sau.com.au/forums/topic/424367-steering-clunks-at-low-speed/
Yeah, ok. Im familiar with the part as I have previously replaced the steering knuckles on the car, but does anyone know, it the lower ball joint a part I could theoretically change myself, or is that one for a workshop that would press it in on a bench with the proper press/tools?
If the ball joint is clunking, it means that the socket is worn and grease will do nothing. If you can feel any play in the socket by hand, it means it needs replacing
Replacing them is easy if you have all the tools. You'll need:
A small hydraulic press (6 tons was enough)
Circlip pliers
Various pieces of metal tube.
I used a piece of 60mm wide steel tube with 4mm thick walls and put it underneath the ball joint, then used another piece of tubing over the pin to push the ball joint body through the hole, which then falls into the 60mm tube. Dont forget to remove the circlip first, they are usually hidden under dirt.
The most labour intense bit is usually getting the tapered pin out of the hub, unless you've got a ball joint clamp.
Ahh crud. If I had a house and garage I would no doubt invest in the press and use it for many a year, but being in a rental appartment, I think this is one for Padders. Anyone know what the labour on this might be?
cool. I actually have a spare set of LCA but they are modified to be longer (to be used with the modified knuckles i have in a box) so either way I might just get a shop to replace the standard arms themselves if thats infact the issue. Thanks
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
