So ive noticed that when Im steering at really low speed I tend to get a clunk sound as if there is play in the steering and its starting to get my interest. Steering feels fine, no real issue there but the clunk has got my attention as its annoying. Anyone have this problem? Fixes?
https://www.sau.com.au/forums/topic/424367-steering-clunks-at-low-speed/
Yeah, ok. Im familiar with the part as I have previously replaced the steering knuckles on the car, but does anyone know, it the lower ball joint a part I could theoretically change myself, or is that one for a workshop that would press it in on a bench with the proper press/tools?
If the ball joint is clunking, it means that the socket is worn and grease will do nothing. If you can feel any play in the socket by hand, it means it needs replacing
Replacing them is easy if you have all the tools. You'll need:
A small hydraulic press (6 tons was enough)
Circlip pliers
Various pieces of metal tube.
I used a piece of 60mm wide steel tube with 4mm thick walls and put it underneath the ball joint, then used another piece of tubing over the pin to push the ball joint body through the hole, which then falls into the 60mm tube. Dont forget to remove the circlip first, they are usually hidden under dirt.
The most labour intense bit is usually getting the tapered pin out of the hub, unless you've got a ball joint clamp.
Ahh crud. If I had a house and garage I would no doubt invest in the press and use it for many a year, but being in a rental appartment, I think this is one for Padders. Anyone know what the labour on this might be?
cool. I actually have a spare set of LCA but they are modified to be longer (to be used with the modified knuckles i have in a box) so either way I might just get a shop to replace the standard arms themselves if thats infact the issue. Thanks
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
